Seat Belt Replacement
Richard240
Post by Richard240 »
Does anyone have a source for new seatbels for my 1981 Spider 2000? I found some universal sets but only in black. I need Fiat maroon/burgandy or close.
The original ones are very faded and plastic is badly deteriorated.
vandor
Re: Seat Belt Replacement
Post by vandor »
Seatbelt Planet has them for Spiders, I assume they have different colors. The price is ~$230.
Holshot
Your car is a: 1982 TURBO Spider 1979 Spider
Post by Holshot »
My vote goes to seatbeltplanet.com as well... I just received mine a few weeks ago and they fit perfect. Just be sure to save all your original hardware as they only come with the belts/mechanism. They install the same exact way as the originals but be sure to ask for the Spider specific set. As of when I placed my order they did not have it listed on there site and I ordered a universal kit through their website and luckily I had changed my mind with the receiver side where the belt clicks into.
I had originally ordered the same exact length as the factory one which is 12" with a 9". I decided to go with the 9" because I'm 6'3" and have the seat all the way back and the 12" seems to protrude to much and I didn't like the look of that much showing. When I called back the following day to switch them out I got a guy named Steve and while chatting I mentioned they were for a Fiat Spider, he took a look at the order and told while what I ordered would work he actually had a direct kit that would work better and he switched out the original order for the kit that was specifically designed for the Spider.
I actually got around to installing it just last week and it fit perfect! He told me he was working on getting it on the website so who knows, maybe it's listed by now. Here is the part number if you need it #510110 and I also ordered new bolt caps as mine were originally blue and I switched to black. I'm not sure they have maroon but you could always ask... Hope that helps!
Giuseppe
1979 Fiat Spider
1982 Fiat Spider TURBO
1984 Pinninfarina Spider (gone but not forgotten)
ga.spyder
Post by ga.spyder »
I ordered a set years ago from https://www.gotbelts.com/ They have looked great and worked flawlessly.Not sure about the color choices, but they were priced great.I was directed there by other Spider owners
Craig Nelson
Fling It Around Turns !
njoconnor
Your car is a: 1972 124 Spider
Post by njoconnor »
At long last got the retractable shoulder belt sets from http://www.seatbeltplanet.com installed:
I also worked with Steve last NOV, and he asked me to send the diagonal measurement from the rear mounting point ion the inner wheel well down to the belt anchor point on the outboard side of the cockpit (at the left rear of the driver seat). I installed them today (see post in Restoration) and I'm really pleased with how well they work. As I expected, one must be smooth and easy with pulling the belt out (the retractor locks are sensitive in this orientation), but they rode comfortably. I'm using the black plastic shoulder belt guides from one of the vendors, but may decide to opt for the metal ones as a partial upgrade.
I would definitely NOT choose the solid plastic holsters again. My mistake entirely; should have gone (and will probably retrofit) cable mounts for the inboard belt receivers. Between the new (slightly wider) console, and the refilled/upholstered seats, it's pretty tight on the inboard sides of the seats.
Definitely recommend seatbeltplanet. Steve knows his stuff, and they ship fast.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
torino06
Post by torino06 »
i am also in need of a seat belt for our 1979 fiat 2000. i noticed on the website most run for $70 and i saw above that it was costing $230... can anyone tell me what they are paying?
njoconnor
Post by njoconnor »
I paid $210 for 4 belt sets: two rear (extra long to hold down golf clubs and Martin Guitars!), and two front 3 way belt sets. My fronts were special order because of the change to the inertia reel system to all angles from vertical only. Snap a pic of the original installation, contact Steve, and send him a copy. He'll help you figure out the solution for your car.
Note to early car owners: I had to modify the outer rear trim panels to allow the retractors to fit in the factory mounting points. Once the top is back and installed, I'll post some pix of the process and the mods. For now, the panels are back in, unsecured, to make sure the new speakers fit (Blaupunkts with blue poly cones...yeah..more blue). Top frame comes home this week.
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
