Page 1 of 55
Edit... Resto mod FIRST DRIVE
Posted: Sun Apr 27, 2014 7:04 pm
by SoFlaFiat
I've been busy with rigging my engine bay and wiring the whole car. Still have brake and fuel lines to fit but getting there...
Re: Engine bay coming together
Posted: Sun Apr 27, 2014 7:55 pm
by 70spider
WOW, talk about a complete rebuild. Nice job by the way, totaly jealous
. When I win the lottery I'll do that with my '70 excluding the electrical. Again nice job.
Posted: Sun Apr 27, 2014 11:07 pm
by BEEK
nice
Posted: Sun Apr 27, 2014 11:57 pm
by Holshot
Absolutely STUNNING! Great job and attention to detail.... Is that some sort of custom cold air intake welded/grafted into the driver side fender?
Posted: Mon Apr 28, 2014 12:18 am
by juvius
Very nice...
Posted: Mon Apr 28, 2014 1:28 am
by kev
Wow that is looking real nice.
Posted: Mon Apr 28, 2014 5:40 am
by SoFlaFiat
Thanks gang!!! The kudos are very motivating!!
Giuseppe, yes, you guessed it. Cold air intake. I've seen pictures of your work and you redefine "attention to detail"!!
Here's a better picture,
The other side...
Posted: Mon Apr 28, 2014 5:49 am
by SoFlaFiat
Couple more pictures...
This is so much more fun than cleaning crud off the bottom of the car!!
Here is the headlight relay block, mostly for Steve as he is using the same type.
As you can see, I am attempting to out shine Andy.
I will have the 7" high/low H4 and a pair of 5 3/4" H4 mounted below, plus fog lights behind the grill...
Posted: Mon Apr 28, 2014 9:30 am
by cos
very nice! an insiration, well done!
Posted: Mon Apr 28, 2014 1:38 pm
by SoFlaFiat
Too funny...
This inspired me!!
Posted: Tue Apr 29, 2014 2:57 am
by cos
ha ha!
keep the photos coming!
Posted: Tue Apr 29, 2014 7:16 am
by toplessexpat
SoFlaFiat wrote:As you can see, I am attempting to out shine Andy.
absolutely no problem with a a bit of competition!!
Absolutely beautiful job on the build though... Really impressive. Now - if you do a HID conversion you can have more fun!
Posted: Tue Apr 29, 2014 10:55 am
by SoFlaFiat
Thanks Andy! Can I wait with the HID conversion? I have a little bit going on already
I keep adding bits and will post more pictures soon. Fuel and brake lines arriving tomorrow...
Posted: Tue Apr 29, 2014 1:04 pm
by Daniel
Hey SoFlaFiat
What rack and pinion did you use on the car?
Posted: Tue Apr 29, 2014 2:46 pm
by toplessexpat
SoFlaFiat wrote:Thanks Andy! Can I wait with the HID conversion? I have a little bit going on already
Go on then - procrastinate some more!
I've been playing around with a DRL/turn signal LED bulb combined actually. Runs as a DRL, then you put a voltage on the turn signal and it lights up Amber while extinguishing the DRL. After 2 seconds of no turn signal voltage, the DRL lights back up again. I've wired up the DRL side to the parking lights, and fitted the bulb into the top of my headlight housing. This w/end I think they're going to come out though, and be fitted into a Mk3 Golf indicator light that should fit into the square hole... maybe... perhaps...
Now back on the HIDs - at least get the ballasts in now onto the inside wings, will save time later
. I'm trying to work out where to fit all four ballasts for my hood...
A
