choke question
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
choke question
my choke works in that it depresses the gas pedal. however, when i pll the choke out, it will slide back to the original position. is there some kind of adjustment for the tension so it stays in place depending on how far out you pull it?
1975 Fiat 124 Spider
- bradartigue
Re: choke question
That's not a choke. The choke should not pull the gas pedal at all. All the choke does is close the plate(s) on top of the carburetor. You likely have some kind of throttle, but I thought those were eliminated in 1974. 1975 would have had a water-activated choke on a 32ADF carburetor, it requires you to press the pedal to the floor when the engine is cold, then take your foot off the gas, start the car, and let it warm up.btoran wrote:my choke works in that it depresses the gas pedal. however, when i pll the choke out, it will slide back to the original position. is there some kind of adjustment for the tension so it stays in place depending on how far out you pull it?
1970 124 Spider
http://www.artigue.com/fiat
- spiderdan
- Your car is a: 1968 124 Sport Spider
Re: choke question
Agree with Brad. I do not know the 75 but on my 68 the choke is on the left of the steering and the "ICC" Italian Cruise Control" is on the right. The ICC depresses the gas pedal and, if working correctly, stays at the revs you set.btoran wrote:my choke works in that it depresses the gas pedal
You just have to remember to push in the ICC when you want to stop.
I can see why it was discontinued.
Dan
"Angelina"
2015 Toyota Camry XSE (hers)
"Angelina"
- btoran
Re: choke question
mine is to the left of the steering wheel and says "throttle" on it. it definitely drpesses the gas pedal when i pull it out. it just won't stay pulled out.
- engineerted
Re: choke question
If i recall correctly, i though you had to give it a 1/4 trun to keep it in place? I could be wrong.
Ted
Ted
Ted
- btoran
Re: choke question
ted - you're exactly right. thanks much! clearly, i didn't think to try that but it works.
- kilrwail
Re: choke question
FYI My '78 also has the manual throttle, which locks the same way. Don't use it as a cruise control!
Peter Brownhill
1977 Porsche 911S - track car
2022 Ram 4 x 4 - hauler
Peter Brownhill
Re: choke question
I have the throttle cable on my '78. I was having problems with my acellerator stiching and it turned out to be that cable sticking. I disconnected the cable and my problems went away. My suggestion if you have one, ask you self if it is safe.
