heater core tubes
Weelan
heater core tubes
Post by Weelan »
So the P.O. bypassed the heater core, and I've looked at it and I think he only bypassed because of issues with overheating. I had the engine rebuilt, and before I noticed a lot of build up that was blocking flow. I want to reconnect the heater core, I took pictures of it and I think the it'd be ok to maybe flush the core with a low pressure hose and clean it and check for leaks.
Does it look like it's ruined to anyone? I think they're fine.ImageImage
rlux4
Patron 2022
Patron 2022
Re: heater core tubes
Post by rlux4 »
Usually a heater core is bypassed because of a leak. Either the core itself or the heater valve. To bypass it because of overheating would almost be counter-productive. An old trick to help while overheating is to open the heater and because the heater core is a small radiator some heat is dissipated by it.
Ron Luxmore
rlux2n2@gmail.com
you're virtually guaranteed a leak at the tube seals. Once the seals dry out from being bypassed, they need to be replaced
Weelan
Post by Weelan »
Darn, I was hopefully. Glad I checked first. I'll work on pulling that stuff out. For now I might bypass it just to get the car running so I can enjoy it some. Although that's a lot of effort redoing the coolant, I'll see what I can find for where a leak is.
wizard124
Post by wizard124 »
From an earlier post of mine:
I dropped the heater core. There was some crud visible. Flushing with a garden hose removed a good bit of stuff, but i could see there was more residue. I needed to try something more. I ended up using "Simple Green/ Lime Scale remover". This comes in a spray bottle. CLR warns not to use on brass/aluminum...this product does not state this limitation. I figured it must be gentler and it has a different active ingredient. I used it straight out of the bottle and let it soak for 5 minutes, flushed and repeated a second time (used the entire contents). Some ugly blackish water/cleaner flushed out so it must have had some effect. No leaks so it is ready to go back in. :)
I my case the valve was frozen and completely plugged. But my core was leak free.
Weelan
Post by Weelan »
Cool, good to know. I'll give that a shot. Thank you
