Hi,
I forgot to order an o-ring for an electronic distributor, thinking I should be able to source locally: Does anyone have the specs?
...Can I use the regular gasket as a stop-gap?
Mark
Distributor O-ring Spec
- opus10583
- Your car is a: 1978 CS1
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
Re: Distributor O-ring Spec
The one that came with my gasket kit was to big so I got something way smaller but beefier from Home Depot and it was not easy to get the thing installed. Seems to be working, its seal.
- opus10583
opus10583 wrote:Hi,
I forgot to order an o-ring for an electronic distributor; I'm thinking I should be able to source it locally: Does anyone have the specs?
Mark
That should seal it but it would probably bake on and you could not change the timing later.
