Overfill Differential?
- tartan18
A year ago I had my differential rebuilt as it had a major leak. It is a 4.3 Even with the rebuilding (new pinion shaft and seal) it sill had about a drop of fluid every day. Yesterday I jacked my car up (a 1975) and squirted in a half quart of 80/90 EP (until it began to flow out of the fill hole. Now I am wondering if I overfilled it because I only jacked the car up from the rear. Is this something I should be concerned over?
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
- azruss
Re: Overfill Differential?
I wouldn't worry about that little difference.
Drive it. Unless you had the back end 3ft in the air it aint gonna be enough overfull to worry bout.
- tartan18
Thanks for easing my mind. Much appreciated
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
