Replacing Speedometer Cable
davery
Your car is a: 1985 Spider
Post by davery »
I need to replace my speedometer cable. Any insights, tricks, directions?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
narfire
Re: Replacing Speedometer Cable
Post by narfire »
Not really. A bit fiddley getting it through the firewall and then getting the rubber seal in place.
Dougieb
Your car is a: 1972Spider
Post by Dougieb »
The cable ends are different sizes.
If you try to put it in backwards, you could be under the car for more than
30 minutes before you realize the error of your ways.
Don't ask how I know.
azruss
Post by azruss »
The speedo connection is the hardest part. The late model cars use a clip connector on the speedo, where the early cars use a screw on. Do the speedo first before you go under the car. make sure you lube the cable well. I use stuff called tri-flow. available in a rattle can.
davery
Post by davery »
So I pulled the gauge plate to get to the back of the speedometer and it looked like it had just come loose. All this started when I had the master cylinder leak and had to loosen the brake booster to repaint. I must have pulled on the speedometer cable a little to hard. Anyway, it looks like it just went back in, although some of the plastic clips may have broken. It appears to be working.
Don Avery
1985 Pininfarina
2011 Eos
Post by RRoller123 »
Lucky!
