Door lugs
kolls
Your car is a: 1980 fiat spider
Door lugs
Post by kolls »
We'll I decided to try and make a set of door lugs . Here is what I used
1. Door lug guides
2. Piece of plywood
3. Vice
4. Some fiberglass resin
4. And not but least PAM . Yes the PAM you use on your skillets
SunnySideUp
Your car is a: SOLD
Re: Door lugs
Post by SunnySideUp »
Seems like a lot of work. Won't the plywood swell and contract throughout the year and change the fit? I know the typical rubber lugs (or after market plastic ones) that came with the car wear out and disintegrate. Have you looked at the ones that Allisons' Automotive has available? They are made of delrin (type of nylon) that will probably last longer than the car and the package comes with new fasteners, too. I've had the delrin lugs on my Spider for a couple of years and they work great. Considering that time equals money the delrin lugs are a far less expensive (and easier!) solution in my opinion.
SunnySideUp
kolls
Re: Door lugs
Post by kolls »
I used the door lug guides as molds to make them from fiberglass resin . I took the door lug guides and sandwiched a piece of plywood between them and sprayed the inside of the door lug guides with Pam and then poured the fiber glass resin. then drilled and counter sunk the holes .
azruss
Re: Door lugs
Post by azruss »
did you use laminating resin or casting resin. Laminating resin will crack right away in this application. They both will be brittle. Delrin, nylon, UHMW are all easily attained plastics where you can make you new ones after your polyester ones fail. :roll:
oldflyer
Re: Door lugs
Post by oldflyer »
I had to make the lugs. had a small piece of 3/8 in. thick vinyl that was scrape from a basketball flooring in the gym.
can cut easily with sharp knife and seems to do the job.
fiat218
Re: Door lugs
Post by fiat218 »
Can't buy some? Or what
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
kolls
Re: Door lugs
Post by kolls »
Actually it's polyurethane resin not fiberglass resin. We use this at my work uraseal makes it. Worked really well. Most of the new ones u buy are plastic and break overtime and if I can save myself 20-30 dollars but for me it's not about that it's the challenge. And most important spending time in the garage instead of being in the house :P
profcucchi
Your car is a: 1979 Fiat 2000
Re: Door lugs
Post by profcucchi »
I was told by a Fiat restorer that the lugs are un-necessary because as the door sags, they'll make it worse.
Anyone know this to be true?
1979 Fiat 2000 "Luigi"
kolls
Re: Door lugs
Post by kolls »
That would not be true because the door lugs help keep all the weight off the hinges and tearing more
Re: Door lugs
the lugs prevent the door from sagging. I can't imagine anyone familiar with Spiders suggesting they're not needed. They must enjoy welding up cracked doors :cry:
profcucchi
Re: Door lugs
So Cal Mark wrote:the lugs prevent the door from sagging. I can't imagine anyone familiar with Spiders suggesting they're not needed. They must enjoy welding up cracked doors :cry:
Thanks, Mark.
The more I think about this mechanic, the more upset I become. This didn't help.
profcucchi
Re: Door lugs
I'll get new lugs next year, but I quickly made one out of thick, reasonably hard rubber. Once I painted it red, like the one I have, the door works well.
A quick fix, but better than being told by my former mechanic that it's not necessary.
Thanks all.
fiasco
Your car is a: 1969 Fiat Spider
Re: Door lugs
Post by fiasco »
Best DIY solution I've heard of is to cut them out of hockey pucks on a band saw.
http://fiatspider.com/f08/viewtopic.php ... key#p64526
-- se
Steve Eubanks
1969 Fiat 124 Spider AS | 2108 Fiat 124 Spider Classica | http://calstylestudio.com
Re: Door lugs
but that ruins a good hockey puck
