engine not engaging. flywheel?
Juarez
Post by Juarez »
Hearing this awful noise from the starter the section, sounds like a gear grind or chain pulling all sorts of wrong on a bike. While trying to start It can make that noise for a moment then stop suddenly ( from a build up of tension?) Then just start to make this noise and shake my engine. At a bit of a stand still past few weeks. :cry:
In process of taking out the starter, which I just realized is a jerk to remove lol specifically the top bolt just at the start of the transmission cave.
Ideas? :D
Juarez
Re: engine not engaging. flywheel?
Post by Juarez »
I'll try to shoot a video of the start today, so thar may help what I tried to explain.
hamlet
Post by hamlet »
I just went through this myself. I'm in the process of getting the transmission out, and I can see the ring gear and it's not in bad shape. Is the starter not getting enough power to engage? But if that were the case, rolling the car a few feet in gear wouldn't allow the car to start again. Hmm... Any ideas guys?
