confusing engine block and head numbers
deang
Post by deang »
I picked up a used engine from a '79 spider thinking I could use some parts on my '81 (need a new block).
The number on the head and block aren't on any list I've found. Also, the head doesn't have the extra emissions port I was expecting, just the 4 exhaust holes. The exhaust manifold does have the extra hole but it's been plugged.
Engine block #'s 132 DB 2A 0 - 4358114
Head #'s 32AB9A - 4277590
The engine looks almost unused but what is it?
JohnD
Your car is a: 1971 Fiat Spider 1608cc
Re: confusing engine block and head numbers
Post by JohnD »
Google the head and found this ebay link - says it is a 74- 76 head
http://www.ebay.com/itm/1974-76-Fiat-Cy ... 1217034229
This link on mirafiori.com
http://archive.mirafiori.com/show.php?f ... 36#2_13844\\
Does this help at least for the head?
John D.Nicosia
deang
Post by deang »
Thanks it help some. What the reason for that head on that engine I wonder.
131
Post by 131 »
deang wrote:Engine block #'s 132 DB 2A 0 - 4358114
That looks like the number cast into the side of the block, you need the numbers stamped into the flat machined area near the oil filter housing.
Mick.
