So I'm trying to put the new belt on ('75 spider) but need about another 1/8" to get it to slip over the new tensioner.
I know the new belt and tensioner are correct.
My question is, does the adjusting bracket that the tensioner fits on have a mechanical stop that prevents me from moving it beyond a certain point?
I've checked and triple checked that the belt is properly positioned on all the pulleys.
Any help would be greatly appreciated.
Jeff
timing belt
- Your car is a: 1975 spider
Re: timing belt
Never mind, brute force to move tensioner.
- smbaird37
- Your car is a: 1971 Spider
Re: timing belt
I was having the same difficulty on my 72 spider. I could not apply enough force to the tensioner to give me sufficient slack. I solved it by popping the spring out of the adjusting plate. That allowed me to get the belt on - still a bit of a fight while keeping everything aligned I have to say. Then get the spring back into place with a screwdriver blade to guide and another to push, worked pretty well. I could post a pic or two if anyone is interested.jlw35 wrote:So I'm trying to put the new belt on ('75 spider) but need about another 1/8" to get it to slip over the new tensioner.
Jeff
~S
1971 124 Spider
1973 VW Adventure Camper
- Your car is a: 1979 Fiat 124 Spider
Re: timing belt
I used an old drum brake tool that has a hook to get enough leverage.
--John
1978 Fiat 124 Spider (for sale soon)
2007 Audi A4
Blog: http://www.technobabelfish.com
2007 Audi A4
Re: timing belt
That's a good idea about the brake drum tool, I'll keep it in mind for next time.
Thank you.
Jeff
Thank you.
Jeff
