Poor Acceleration
- smbaird37
- Your car is a: 1971 Spider
Poor Acceleration
My '71 is running "OK" but accelerates poorly, especially at the higher RPMs when I would expect it to start pulling strongly. Acceleration/power seems to plateau 3-4k rpm and starts misfiring. Timing is set to spec 10° BTDC. Stock DHSA 32 carb is suspect. Possibly getting too lean a mix when the secondary opens?
And since I got your attention, how the hell do you get a screwdriver on the slow idle adjust screw? I can't even see it!
Thanks all!
~Steven
Thanks all!
~Steven
1971 124 Spider
1973 VW Adventure Camper
- seabeelt
- Patron 2019
Re: Poor Acceleration
If its a 1608, timing I have read elsewhere, should be 5 deg BTDC initial timing advance. Not that this will fix your issue, just an observation
R/
R/
- smbaird37
Thanks. It is a 1608 - I'll double check that. I have also read 12° BTDC many places. I should add I checked the mechanical advance and it seems to working (i.e., not frozen or gummy).seabeelt wrote:If its a 1608, timing I have read elsewhere, should be 5 deg BTDC initial timing advance. Not that this will fix your issue, just an observation
R/
1971 124 Spider
if it's a misfire, I'd look closely at the ignition system. It's important to have the points set properly or you will not have any coil saturation time, causing a really weak spark. Those systems are marginal at best, and if not in perfect condition won't work very well
- smbaird37
Thanks Mark. I can say the new points I installed were funky. I had to twist the moving arm to get the bushing parallel to the cam lobes. I will recheck and reset after it's settled in a little. Tomorrow night I will also check for arching in the plug wires.So Cal Mark wrote:if it's a misfire, I'd look closely at the ignition system. It's important to have the points set properly or you not have any coil saturation time, causing a really weak spark. Those systems are marginal at best, and if not in perfect condition won't work very well
1971 124 Spider
Like Mark said, "missing" is usually an ignition issue. Points can bounce too at higher rpm. Did it do this before the funky points?? If so, can you put old set back in??
Hard to find quality points. Keith
- smbaird37
I replaced in sequence the condenser, rotor, and then points. Behavior did not change. That leaves cables or cap...majicwrench wrote:Like Mark said, "missing" is usually an ignition issue. Points can bounce too at higher rpm. Did it do this before the funky points?? If so, can you put old set back in??
When I get the misfire to go away, I have a 34 DMS carb I am hoping will help with the plateau. I'll update this thread after I check the cables for arching. Thanks everyone!
~S
1971 124 Spider
the stock carb should allow it to rev to 6-7k without any issues. Do you have access to an ignition scope?
Another thought...(need to quit thinking) it could be running out of fuel. An issue with cap/rotor/wires should "miss" as it is pulling hard, even at low rpms.
Tis easy to "T" a pressure guage in at carb, run long hose so gauge can be hung on wiper arm, then watch as you accel. Any loss of pressure = problem.
Keith
Keith
- smbaird37
Nope... would be nice though!So Cal Mark wrote:the stock carb should allow it to rev to 6-7k without any issues. Do you have access to an ignition scope?
1971 124 Spider
- smbaird37
T off the vacuum line to the brake booster for example? That would be vacuum not pressure so what am I missing?majicwrench wrote:Another thought...(need to quit thinking) it could be running out of fuel. An issue with cap/rotor/wires should "miss" as it is pulling hard, even at low rpms.
Keith
1971 124 Spider
Sorry could have been clearer. "T" into the fuel inlet line at carb. Everyone should have one of those cheapy round vacuum/pressure gauges. If not, go get one. Then buy a "t" fitting, brass plastic whatever, and 4ft of fuel line (1/4"?) then go drive car. Fuel pressue should never drop at all.
Keith
Keith
- smbaird37
Thanks Keith! Yes I have one and have tested fuel pressure near idle (about 4lb). Did not occur to me to test at higher RPM but I will give a look.majicwrench wrote:Sorry could have been clearer. "T" into the fuel inlet line at carb. Everyone should have one of those cheapy round vacuum/pressure gauges. If not, go get one. Then buy a "t" fitting, brass plastic whatever, and 4ft of fuel line (1/4"?) then go drive car. Fuel pressue should never drop at all.
Keith
1971 124 Spider
Not just higher rpm but when problem occurs. Need to get it out on the road.
fuel issues appear under load, so it's gotta be driven to see what's happenin'.
While ignition issues usually appear under heavy load, especially acceleration, your funky points could be causing the problem
