IDLING TOO HIGH
blusmith
Your car is a: 1982 124 spyder
IDLING TOO HIGH
Post by blusmith »
82 FI and motor just rebuilt and in car > She cold -starts & runs well ;Static and dynamic timing is right on 10degree mark; New air pipes so I don't think she's cheating and getting stray air form anywhere; Throttle stop screw is backed right off but still wants to idle at 1200 rpm and I can't get it any lower . What am I missing??
narfire
Re: IDLING TOO HIGH
Post by narfire »
I believe to set the throttle plate you back it all the way off so the butterfly is fully closed and then adjust the screw so the plate is just off its stops. (just a hair open?) Then adjust the engine speed with the screw, think it has a hex head, on the intake. It is on the other side of the plate adjustment.
I had a ton of issues like you trying to get the car to idle properly, but eventually realized or found my brake booster was pooched and letting unmetered air in that way. You can block off the booster hose and try and set the idle perhaps if you are wondering. Also some will spray a little carb or brake cleaner around and of the joints or plastic intake hose to see if it will get sucked in . I did a baseline by spraying a tad into the air cleaner to hear the change.
Good luck
Chris
Re: IDLING TOO HIGH
Post by RRoller123 »
Make sure the cable is adjusted so that there is just a slight amount of slack when at fully closed throttle. It could be holding the plate open if it is too tight.
blusmith
Re: IDLING TOO HIGH
Post by blusmith »
Thanks gentlemen Will do as suggested.
Re: IDLING TOO HIGH
The 2 locknuts for the throttle cable BOTH go BEHIND the fork, NOT one on either side. It is counterintuitive, but that is the correct way they should be configured. :D
81SPIDERMATT
Re: IDLING TOO HIGH
Post by 81SPIDERMATT »
RRoller123 wrote:The 2 locknuts for the throttle cable BOTH go BEHIND the fork, NOT one on either side. It is counterintuitive, but that is the correct way they should be configured. :D
what???? is behind the fork away from engine center ??? got to go look at mine....
Re: IDLING TOO HIGH
Yep, you can see it pretty well in this pic, the 2 locking nuts for the throttle cable are on the outboard side of the fork.
Pete
4uall
Re: IDLING TOO HIGH
Post by 4uall »
ditto
81SPIDERMATT
Re: IDLING TOO HIGH
huh .... guess i gotta fix that ... i got one on either side... and one strand popped on my cable..love those blue hoses.. no clamps.. looks clean . thanks guys and sorry to OP did not mean to hijack your thread... how is your problem solving going???
TX82FIAT
Re: IDLING TOO HIGH
Post by TX82FIAT »
I think we have all done the throttle cable adjustment wrong at some point. Question, when you start the car cold does it idle normal and climb as the car warms up over 15-20 minutes of driving so you notice it at high idle when you stop? or is it right at 1200 rmp from the start?
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
blusmith
Re: IDLING TOO HIGH
Post by blusmith »
Hi: It Idles hi right from the start . I hope to get some time with the car tomorrow and will check that the throttle valve is seating "properly closed". IS there anything I need to check in the AFM?
Re: IDLING TOO HIGH
make sure the afm flap closes completely and doesn't stick
blusmith
Re: IDLING TOO HIGH
Post by blusmith »
Thanks will do
blusmith
Re: IDLING TOO HIGH
Post by blusmith »
Thanks everybody: The AFM flap was held open a few mm so I adjusted the rubber block and I didn't have enough slack in the accelerator cable evn tho the lock nut was right "in" Chris
