I have a recently acquired '79 124; a feast for my senses.
I am attempting to cure at least one persistent oil leak on the driver's side from I believe the area above and behind the oil filter housing. I've heard rumors of an apparatus called the Oil/Vapor Separator.
Has anyone run across a DIY guide for servicing it? Do I need to remove the intake manifold to access it? I have a hunch that it's clogged or one of the rubber hoses is leaking.
Thanks to all in advance!
Is their a DIY guide for servicing the oil/vapor separator?
- Wheel
- Your car is a: 1982 Fiat Spider
Re: Is their a DIY guide for servicing the oil/vapor separator?
Is this what you are looking for? Check this link.
http://www.fiatspider.com/f08/viewtopic.php?f=5&t=16291
If it is, I did not have to remove the intake manifold.
1982 Fiat Spider
Thanks Wheel!
I'm going to do this in the next week or so.
