Exhaust manifold to downpipe bolts/studs?
splitime
Post by splitime »
I just picked up a 'new' used 4-2-1 exhaust manifold to put on my '78 spider. It did not come with the bolts/studs to couple the downpipe to the manifold. I was wondering whether to use a stud or bolt in this location and what the specifications were for the stud or bolt.
Dave
Re: Exhaust manifold to downpipe bolts/studs?
I'd use studs, 8mm x 1.25
splitime
Post by splitime »
So Cal Mark wrote:I'd use studs, 8mm x 1.25
Thanks, couldn't find that detail anywhere it felt like.
The boxes were not sorted well at the hardware store, but I purchased what I believe were 40mm long ones. They were "Just" long enough to start threading and using lock washers got nicely tightened up.
