When I installed the speedo cable, all went great, no issues at all
When I was installing the starter I did notice this small rubber seal on the cable, I suppose when I was pulling it thru it just slipped down and I never noticed it,where would that rubber seal go? Bottom,or top
Speedo cable
Speedo cable
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 81SPIDERMATT
Re: Speedo cable
firewall hole is where mine is... figured it was some attempt at protecting cable from a rough edge
Re: Speedo cable
What is the diameter of the seal you are asking about. There is a seal at the firewall as mentioned. However, there is another little seal that goes on the speedo line at the transmission mounting point. The little 1/2 inch seal helps prevent the very common transmission oil drip where the speedo line connects.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Re: Speedo cable
1/2 "TX82FIAT wrote:What is the diameter of the seal you are asking about. There is a seal at the firewall as mentioned. However, there is another little seal that goes on the speedo line at the transmission mounting point. The little 1/2 inch seal helps prevent the very common transmission oil drip where the speedo line connects.
Ok thanks I know where it goes, it must have got hung up at the time and I never noticed it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: Speedo cable
Got it fixed, thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
