Ok, so I did something stupid, and now I need help finding TDC on #4 cylinder. Long story short, while changing my timing belt, I ended up turning the crank and cams without the belt on and now I don't know where TDC on #4 is. I I have Marks distributorless ignition installed, so I can't look for the rotor pointing to plug #4.
If you want the gory details... I changed the belt, and all was well until I noticed the intake cam gear was wobbling slightly. I put a wrench on the cam bolt to tighten it, and the gear slipped a couple of teeth on the belt. I don't know how I managed to do it, but somehow when I lined things back up I screwed up the crank and cam marks, so I think I have the crank out 180 degrees.
Finding TDC ***RESOLVED***
- kustom
Phill
1981 Spider
2014 Ram 1500 Eco Diesel
2007 Acura TL
1981 Spider
2007 Acura TL
- azruss
Re: Finding TDC
If the crank pulley is still on, you can just align the timing mark to the long one. If not, pull #1 sparkplug, put a drinking straw or something like that down the hole to the top of the piston. now you can watch the piston go up and down. #1 and #4 work the same.
Re: Finding TDC
the ignition is a waste spark, so it doesn't matter if it's firing on 1 or 4. Put 1 at tdc and line up the cams, then set the trigger unit according to the installation instructions
- kustom
Re: Finding TDC
Thanks guys... I will get things "lined up" and give it a shot.
Phill
1981 Spider
2007 Acura TL
1981 Spider
2007 Acura TL
Re: Finding TDC
Could you be off?
Being exhaust,or firing
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- kustom
Re: Finding TDC ***RESOLVED***
Thanks Mark,
Got it running great. That wasted spark system sure makes it easy!
Phill
1981 Spider
2007 Acura TL
1981 Spider
2007 Acura TL
