Valve / Cam clearances
kustom
Post by kustom »
I just checked the clearances on my cams, and every valve measures out to .012 on both intake and exhaust. I can only assume that the PO set it this way intentionally, as every valve measures the same. I started measuring because of what I thought was some valve ticking noise from excessive gap on the valves. Maybe I have a small exhaust leak. I know .012 is too tight, but what issues will arise if I leave it this way? Thanks in advance!
Phill
1981 Spider
2014 Ram 1500 Eco Diesel
2007 Acura TL
Re: Valve / Cam clearances
you'll get more lift and longer duration with that clearance. Setting the clearances like that will give you an indication of whether or not a performance cam will work well in your engine
kustom
Post by kustom »
It runs great the way it is... I just wasn't sure if I was damaging anything, or prematurely wearing my cam. I guess I'll leave things as they are.
Phill
1981 Spider
2007 Acura TL
