rear brake caliper bushing
Has anyone had any luck replacing the bushings for the emergency brake lever shaft of the rear calipers? I am rebuilding the rear calipers on my '79 and on of the bushings is toast. Seems like a long shot trying to source one but hoping someone has found a replacement that works - otherwise, anyone selling a rebuildable rear left caliper or at least the body of one? I don't want to dish out $95 for a rebuilt one just because of a $.30 bushing.
- rjkoop
Re: rear brake caliper bushing
Did you ever find one of these bushing? I'm looking for one too.rrs wrote:Has anyone had any luck replacing the bushings for the emergency brake lever shaft of the rear calipers? I am rebuilding the rear calipers on my '79 and on of the bushings is toast. Seems like a long shot trying to source one but hoping someone has found a replacement that works - otherwise, anyone selling a rebuildable rear left caliper or at least the body of one? I don't want to dish out $95 for a rebuilt one just because of a $.30 bushing.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- Ptoneill
I found them on the C. Obert&Co site under rear brake components...$16 dollars per...very expensive and made of brass unlike the original steel races, the new ones are very soft. I was able to get the new one installed however I was not carefully enough and damaged the lip a little, it still works however I cannot get the snap ring seated.
A machinist may have a better solution or replacement race of higher quality.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
