Adjusting parking question
I have rebuilt the rear calipers and installed a new brake cable. I have not filled the system with fluid. I can not get the parking brake to lock the rear wheels no matter how tight I make it. Do you need fluid in the system to adjust the hand brake? I believe that I have installed the mechanism in the calipers correctly.
- TulsaSpider
Re: Adjusting parking question
Yes the system needs to be working properly, then adjust
If you manually move the parking brake lever on the caliper (use a screwdriver for leverage)
you should be able to see the piston move.
Okay thanks
I can see the piston move. I can lock them up by manually by pushing the lever on the calipers by hand but the cable does not do it. I guess I need it bled first. I initially had one mechanism wrong. If you assemble it backwards, it will still move the piston but not enough and what a pain to assemble it either way. I had to modify a c clamp to get it together.
