Anyone have a keen way on how to reattach the return spring? I replaced the booster today, and disconnected the brake pedal return spring. I could not restretch it and get it in place. Instead, I took a key ring, the kind you pry open to get the key into and wind the key 1 1 /2 turns around and the ring closes. Used the key ring on the pedal box sheet metal, and stretched the spring on the ring. Done.
I wonder if you even need the return spring.
- Your car is a: 1979 124 spyder
Re: brake pedal return spring
Maybe you don't have the right spring, bcs I never had trouble reattaching these by just pulling on one end with a flatblade screwdriver.
That would be my guess as well. I swapped my B booster a few weeks ago and the spring was not really difficult to put back on.
Now the clutch spring.... what a PIA..
