Heater door servicing
Turns out I do have a stuck heater door under the cowl. Does anyone remember the thread that addresses removing the cowl? Cannot find it here or in the service manual. Thanks
Re: Heater door servicing
Once you pop the hood you will see 6 philips head screws that secure the cowl panel. Remove those and gently slide the panel forward. Lift the rear edges and tilt it forward. Be careful with the connector wires and fluid tubes
It helps to have a helper. You may want to put tape on the fenders next to the cowl to reduce the chance of scratching them.
Be careful as they say about scratching the fenders it is really easy to do!
- azruss
I have the best results tucking a couple of terry cloth towels under each corner of the cowl when pulling it out.
Painters tape also works
- giuliot60
- Your car is a: 81 Fiat Turbo removed Spider
I've had mine off a couple of times. Fairly easy to do.
On a side note. I'm getting a musty metal smell inside the car now that I'm using the heater in cooler weather. Will that just go away, or is there something else happening? The car was off the road for about 4 years. Should I spray some Fabreeze into the core unit and/or vents?
Giulio/Charlotte
It may be a dead rat. My car was set up for about 3 years in a garage and I found one behind the heater control valve while I was replacing it. Just something to look for.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- giuliot60
There was evidence of field mice (poop everywhere) even a dead one in the spare tire compartment (PO had rat poison in the car). There was no mice in the heater core area with the cowl off. Just a couple of wasp nests.
I need to explore a little more.
Giulio/Charlotte
- giuliot60
You jinxed me Dennis. Guess what went on me this afternoon. I'll let you know if I see any corpses.dmwhiteoak wrote:It may be a dead rat. My car was set up for about 3 years in a garage and I found one behind the heater control valve while I was replacing it. Just something to look for.
Giulio/Charlotte
