Replacing the V-Belt
Danno
Post by Danno »
I need to replace the V-Belt that runs the water pump and alternator. Am I right that there are two listed because one is for the smog pump (the shorter of the two) which I no longer have?
Also, I've never had a vBelt that has cogs on the underside. is that ok? Seems like it should be fine, just never had one like that before.
4uall
Re: Replacing the V-Belt
Post by 4uall »
mine had teeth as well
Danno
Post by Danno »
OK, cross reference using your box numbers tells me that I need the one on the left in my picture. That's what I thought.
Seems like cogged is the way to go per my google searches. Something about heat dissipation and reduced belt wear from constant deformation...
Thanks!
