Oil leaking from exhaust manifold bolt
I know this has been discussed before, but wanted to confirm. I had the manifold gasket replaced in the spring when I was having some other work done. It was leaking oil from the last bolt closest to firewall. I noticed it has started leaking from there again. I have a feeling they didn't put any sealer on the bolt when re-installing. So, do I need to remove the bolt, add the sealant and re-install? Just tightening will not help...correct?
Re: Oil leaking from exhaust manifold bolt
Remove, add sealant and reinstall. I believe its the top TWO bolts that need to be sealed.
Thanks for confirming that. Second bolt is dry, so I think I'll leave it unless I see leakage from it. The bolt that's leaking is sticking out about an inch not including the nut. Is this normal?Divers wrote:Remove, add sealant and reinstall. I believe its the top TWO bolts that need to be sealed.
I used Teflon tape on mine and seems to work great. I'm not sure what others are using.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Teflon tape? Interesting. How long has it been on, I would think it would have a heat issue. I was wondering what to use as a sealer also. I tried regular locktite and it did not last.
The Teflon has been on a year as of last month and about 20,000 miles. No oil leaks yet.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
