Where is the Thermo Time Switch Located
DMECMAnderson
Post by DMECMAnderson »
I've looked in both my manuals and cannot find where the Thermo Time Switch is on my 91 Spider. Can anyone help me located it?
DMECMAnderson
Sorry '81 Spider, What's a decade...
under the intake manifold, sort of hard to reach. It's got the same connector as an injector so it's easy to spot with a mirror
DMECMAnderson
Thanks, Found it, now I just gotta figure out how to get a wrench on it... Looks like I need a 24mm deep well socket. Guess I'm going to the store (again).
is it keeping the cold start inj on? or not allowing it to work at all?
DMECMAnderson
Long story short. Ordered the wrong part by mistake, generally my car is running OK. Starts a little hard when cold but nothing terrible. I think the car is running rich (noting a black sooty mark at the output of the tail pipe). So I'm changing all the inexpensive (relatively) parts that might affect the fuel injection performance. I agree not very scientific.
One sensor that I thought might be acting up early on in my investigation of my light problem was the temp sensor on the Fuel Injection. I had a (BAD) theory that perhaps the engine was overheating or the sensor was indicating overheat. I thought the ECU may have a mode that would shutdown the car if it detected a serious overheat. (Again I believe this was all fool hearty, too much engineering analysis not enough simple common sense!) I ordered the temp sensor on-line, but in a hurry clicked the wrong part. So I've got the darn thing might as well swap it. Like chicken soup it can't hurt.
Fortunately I don't think that I've changed too many completely functional items. I've found things in my investigation that have been disconnected, putting in the new sensor or part has improved performance...
if you haven't changed that thermo time switch yet, make sure you drain the coolant first or you'll get a bath. The connector to the temp sensor is very problematic, if it doesn't fit the sensor tightly get a new connector.
DMECMAnderson
I plan to do it when I'm working on my heater, need to drain the coolant for that job too, so it's two for one!
