Fitting an Oil Presure Gauge
blusmith
Your car is a: 1982 124 spyder
Post by blusmith »
Hi Have rebuild my '82 engine and I want to fit an oil pressure gauge for my own reassurance How can I do this ?
Chris
Divers
Re: Fitting an Oil Presure Gauge
Post by Divers »
Outside of buying the gauge...
Buy new sender unit
Remove existing oil sending unit from oil boss
Install new pressure sending unit in its place
Remove plug opposite side of oil boss
Screw in the removed oil sending unit
Run new wire from your NEW unit to your new gauge.
Old wires go to where you moved original unit.
blusmith
Post by blusmith »
DocGraphics
Your car is a: 1978 124 spider
Post by DocGraphics »
Here's a link to a great write up on how to install one
http://flumichigan.italiancarclub.com/T ... egauge.pdf
Don Raugust
narfire
Post by narfire »
Mine was a mechanical one. It came with fittings that screwed into the side of the filter boss, (after taking a plug out), and then ran the thin white tube through the firewall and mounted under the dash left side for now. Works great...so far.
majicwrench
Post by majicwrench »
That thin white tube is a disaster waiting to happen. Replace it with a copper tube, any hardware/auto store can fix you up.
keith
bradartigue
Post by bradartigue »
Divers wrote:Outside of buying the gauge...
Buy new sender unit
Hey you forgot this step:
Post on fiatspider.com "Why is my oil pressure reading so low?"
Divers
Post by Divers »
I only installed a pressure gauge for looks...since the stock clock lens sucked so bad. One of those poorly designed stock items.
