New carb
BrwnRecluse
New carb
Post by BrwnRecluse »
I've been fighting a stumble and stalling problem for the last week. Got obsessed with the car, had less than three weeks and I'm about to go back to work. I work out of town so I won't get to play with it.
Anyway, after refurbishing the ignition system, the carb was the only thing left. I ordered a Weber 32/36 DFEV because It's just about the same thing I use on my Mazda trucks. after pulling the stock carb off,
I cleaned the manifold and replaced some really crappy vacuum plugs from the PO. Then ground the back off the 'knob' for the throttle link and mounted the knob to the new carb with the help of a washer and steel epoxy putty.
Ugly, but it works! I need to thread the rod down a bit more to get all the adjustment I can.
Then realized I had forgotten to order a spacer. Really don't want to miss my last weekend of driving weather, so I rednecked a solution.
Temporary, a new spacer is on the way! But I'm riding around in my new spider today!
majicwrench
Re: New carb
Post by majicwrench »
I love "makenerwork". Ya done good.
New carb work better than old??
Keith
BrwnRecluse
Re: New carb
so far. ran around all day with no stumbles!
bradartigue
Re: New carb
Post by bradartigue »
Does it smell like pine sap when you run it?
LIQUIDLOUNGE
Re: New carb
Post by LIQUIDLOUNGE »
Honestly, will the moderators ban this guy. I knew Spider owners were skin-flints, but this guy won't even spring for a more stable wood product such as MDF or Poplar. I've poured $123.00 into my car and its like the Concours d' Elegance of the Spider world.
narfire
Re: New carb
Post by narfire »
Well that is a first...
Make a note to tighten the carb down a bit after a couple of runs. The heat will dry the wood out even more, shrinking it a bit.
djape1977
Your car is a: 1970 fiat 124bc
Re: New carb
Post by djape1977 »
and eventually cracking it.
how expensive can a fiber separator be?
BrwnRecluse
Re: New carb
I have an aluminum spacer on order, it just hasn't gotten here yet. Hey, at least the pine doubles as an air freshener!
Re: New carb
Post by RRoller123 »
AND!!! You can use it as a fire starter in the fireplace after you replace it with the one on order. That baby should burn!
bradartigue
Re: New carb
BrwnRecluse wrote:I have an aluminum spacer on order, it just hasn't gotten here yet. Hey, at least the pine doubles as an air freshener!
Do you have the thick paper gaskets for the opposing sides of the spacer? One between spacer and manifold, one between carb and spacer. Soak them in oil first. You can also make them from cork or that blue gasket material from Auto Bone.
BrwnRecluse
Re: New carb
Isaac has came to visit, so no Spider driving today. Installed the real carb spacer. Shortened and re-threaded the linkage rod to get full pedal travel. My epoxy fix for the 'ball' part of the linkage was starting to fail, so I drilled and tapped the ball, then red loctited it in place. When it quits raining, I'll test it out. My top only keeps the largest raindrops out.
fiat218
Re: New carb
Post by fiat218 »
BrwnRecluse wrote:Isaac has came to visit, so no Spider driving today. Installed the real carb spacer. Shortened and re-threaded the linkage rod to get full pedal travel. My epoxy fix for the 'ball' part of the linkage was starting to fail, so I drilled and tapped the ball, then red loctited it in place. When it quits raining, I'll test it out. My top only keeps the largest raindrops out.
And tell us, how large are the large rain drops. Lol
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Re: New carb
Post by dmwhiteoak »
Hunker down, he looks like he's gonna stick around awhile.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
