Copper washers on my braided brake lines?
maytag
Post by maytag »
Hey y'all:
so I replaced my rubber hoses with Braided steel ones from Allison's. They did not come with copper washers, but I assumed I needed them, so I fit them, top & bottom. Now I find they are leaking.
What did I miss? somebody? anybody? Buehler? :lol:
fiat218
Re: Copper washers on my braided brake lines?
Post by fiat218 »
maytag wrote:Hey y'all:
:roll: maybe that why they leak, u added something that should not have been there?seems to me u need to take your car into some professional place,your wrecking the things that u have installed, clutch etc :shock: :lol:
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
divace73
Post by divace73 »
did you anneal the copper washers? Heat them up till red (I use the kitchen gas stove top at the end of a coat hanger) then put them in cold water??? I always do this to any copper washer I use.
Cheers David
see my >>You tube channel<<
you still need the copper washers with the braided hoses
fiat218
Post by fiat218 »
divace73 wrote:did you anneal the copper washers? Heat them up till red (I use the kitchen gas stove top at the end of a coat hanger) then put them in cold water??? I always do this to any copper washer I use.
y?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Post by fiat218 »
So Cal Mark wrote:you still need the copper washers with the braided hoses
thats what i said lol he needed them :)
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
maytag
Post by maytag »
I used new copper washers. I'm reading in a few threads where Majicwrench suggests it's not unusual for new ones to weep abit. He recommends a few tighten / loosen / tighten sequences.
I'll try this.
But tell me something else:
my banjo bolts do not have a round flare on them at the base that would seal against the washer. they are hexagonal all the way down. Is this correct for these cars? Or has a PO gone and replaced with a non-standard?
divace73
Post by divace73 »
y?
they seal better http://en.wikipedia.org/wiki/Annealing_(metallurgy), I've never had a weeping problem when I have followed this process.
Cheers David
