What do numbers/letters inside piston mean?
dom
Post by dom »
i bought used oversize pistons .4mm oversize and it is stamped on the top. But inside three of the pistons there is 2468e and in one 2468m. Anyone can tell me what the letter stands for? They are mondial. Thanks
bradartigue
Re: What do numbers/letters inside piston mean?
Post by bradartigue »
dom wrote:i bought used oversize pistons .4mm oversize and it is stamped on the top. But inside three of the pistons there is 2468e and in one 2468m. Anyone can tell me what the letter stands for? They are mondial. Thanks
Never heard of an "E" - sure it is not the M turned goofy and/or stamped poorly?
Measure them regardless. 2468M is a common type in our cars and I don't know what it means since 2468M is also available for Alfas, Ferraris, you name it. Your engine shop will cut the bores to the pistons, make sure they mark each one and each one is marked on the block so you can match them.
