New Automatic Transmission pans available?
Fiat88
Post by Fiat88 »
I think my auto trans pan needs replacing. Can't get it to seal without still having small a drip. Looked warped to me from overtightening. Does anyone know where I can get a know one? Does the chevy chevette use the same pan? Thanks for any help!
Re: New Automatic Transmission pans available?
I've got used ones and you might find a new one at a trans parts supply house. That is a TH180 trans that GM used back in the day. Generally you can put the rail on a flat surface and knock the edges of the holes back flat using a ball peen hammer
Fiat88
Post by Fiat88 »
PM sent.
Warren
Post by Warren »
On mine, I always had problems with the cork gasket eventually leaking, swapped to a rubber gasket and still eventually leaked. Also did as Mark suggested and flattened the flange beforehand and still leaked. Final solution was change to a orange RTV seal which you need to let dry for a day and then put back in the fluid. Cleanliness is very important on the joint so wipe off all ATF after thoroughly draining. No leak finally.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Fiat88
Post by Fiat88 »
Warren wrote:On mine, I always had problems with the cork gasket eventually leaking, swapped to a rubber gasket and still eventually leaked. Also did as Mark suggested and flattened the flange beforehand and still leaked. Final solution was change to a orange RTV seal which you need to let dry for a day and then put back in the fluid. Cleanliness is very important on the joint so wipe off all ATF after thoroughly draining. No leak finally.
Do remember how many ft-lbs you torqued the bolts to?
Fiat88
Post by Fiat88 »
Going to install a different pan today with a new gasket. Does 5 ft-lbs sound about right? Should I tighten the bolts in a star pattern? Appreciate any tips!
Warren
Post by Warren »
The Fiat manual says to torque the pan bolts 7 to 10 ft-lbs. It didn't specify but I did mine in a star pattern.
Warren
Sylacauga Alabama
