I need to fix an oil leak that appears to be coming from the exhasust manifold. It's my understanding that some (all) of the bolts/studs need to be sealed because they extend into oil passage on head. I've looked for a gasket for this everywhere and couldn't find one for the manifold to head. Is there a gasket for this if not, what's the best way to install to prevent leaks (oil and air)'
Dan
exhaust manifold gasket?
- divace73
Re: exhaust manifold gasket?
the leak is from the studs that go into the head, it's usually a case of cleanig and putting a thread lock/tape type of material to prevent the leak, not specifcally a gasket.
Cheers David
see my >>You tube channel<<
- RoyBatty
- Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
I have an exhaust gasket in Ione should you still need it. Meet you halfway, say, Angels Camp, if you want it.
Roy
For a FI 82? Is it paper or metallicc? Could you just send it to jamestown?
Call me at 209.984.9066
Thanks Roy
Dan
Thanks Roy
Dan
