OK here's the rub, when I removed the old one I had to use a puller & it destroyed it, only came about half way off & then the outer part came off & left the inner sleeve on the shaft (bearings everywhere), had to use the puller to get that part off too.
I am replacing it anyways so that's not the problem, but putting on the new one after cleaning the mount shaft with emery cloth it will only slide on, with a little wiggling, about half way.
Does this bearing need to be pressed on with the nut & washer or should it slide on by itself?
Do I need to go after the mount a little more with emery cloth or is it OK to use the nut & washer to get it all the way on?
timing belt tensioner bearing installation
- DocGraphics
Don Raugust
- azruss
Re: timing belt tensioner bearing installation
I've never had to press one on, Don.
- kmead
It should slide tightly on with no wiggle. Had the same experience recently, I had to very carefully ensure I cleaned the shaft evenly all the way around using WD40 to soften the oil residue that had built up and cooked on.
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
