Turbo Engine Wire Harness Help
DocFizzix
Post by DocFizzix »
I have been restoring my 82 turbo but hit a snag and need some help. I have everything I need and I will be make a few modifications that I will share later but for now I need some help from someone who has a turbo spider and a digital camera. I need a picture (or a couple pictures) that shows how the added Legend wire harness was installed on the intake side of the motor, I have a good idea but need to double check on a working car. I have a new wire harness from FIAT but it has more hookups than I was expecting so I would like to have a couple reference images so I can figure it out. I do have a wire diagram but it looks different than the actual wire harness couplers, that is why I need a couple reference image. Thanks so much for your help from one FIAT lover to another
giuliot60
Your car is a: 81 Fiat Turbo removed Spider
Re: Turbo Engine Wire Harness Help
Post by giuliot60 »
I recently purchased an 81 turbo, the turbo was removed but I have all the parts (I think) for it. I did get a turbo PDF that may be of help to you from another 81 turbo owner that is still running the turbo. PM me and I'll send you the file, I believe there are some wiring/electrical diagrams in it. I'll look through my files and see if there is anything else I can send you.
I may still have some of the wiring since it's an original owner car and I don't think the harness was changed.
Giulio/Charlotte
kmead
Your car is a: 1969 850 SC 1970 124 SC 85 X19
Post by kmead »
Could you also send me the PDF info as well?
karlmead at g mail dot com
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
DocFizzix
Post by DocFizzix »
Thanks much, I sent you a PM with my email.
giuliot60
Post by giuliot60 »
Any progress?
Giulio/Charlotte
