HI all-total newbie here so please bear with me...
I just purchased my 1st Fiat and have several questions, but this one first:
On the passenger side, near the coolant bottle, there is a hose (maybe 1.250" O.D.) that runs through the fire wall. Mine has been cut off about an inch short of the firewall...what is that hose for and should it be repaired?
All help is welcome! Thanks!
Mark Welle Jr
Hose cut near coolant bottle
Re: Hose cut near coolant bottle
That is the heater hose to/from the heater located under the dash. There should be two hoses actually.
Take a look under the exhaust manifold. There should be a metal pipe from the back of the water pump to close to the fire wall. The end kicks up and the heater hose is attached to this and the return is attached to a port/short pipe on the head. Perhaps the previous owner has by-passed the heater and you'll find a hose from the metal pipe to the top of the head. Not an issue if you don't need defrost or heat in the car.
Thanks for the reply-not sure...heater/defrost works great. This hose (what's left of it) is right up in the top corner, only an inch or 2 below the hood, near the data plate with paint numbers, etc... Is that the same one you're referring to?
You can post a pic, that would be a great help:
This is a procedure that I have been developing for a little while on how to post pictures here in the Forum. Hope it is useful, and comments are always welcome.
HOW TO POST PICTURES IN FIATSPIDER.COM
Well that picture-posting thing sure is confusing. Took me forever to figure it out. Here is what I do:
First, you must post your pictures on photobucket.com or one of the similar competing websites. You can't post pics directly from your computer. So set up a free account there first. The instructions here reference photobucket.com.
Then in your FS.com post, look for the "Img" box at the top of the post, #9 from the left in the row of command icons.
Put the cursor where you want the pic to appear in the post (leave a few spaces after text is a good idea) and click the "Img" button/icon above.
Then go to the photobucket.com site (or competitor) and find your pic. Hover the cursor over the pic and a drop down menu will appear. Then click the "Direct Link" or similar button. In Photobucket, it will respond with a "copied" indication.
Go back to your FS.com post and make sure the cursor is EXACTLY in between the 2 Img boxes: [img](cursor%20in%20here)[/img] then right click and hit "paste" and the web link for the pic will show up in between the 2 img boxes. DON'T hit the IMG button a second time. MOVE your cursor out of the IMG info you just created before you hit enter.
Now when you post the post, the pic will be there!
Remember that if you delete the photobucket "master" pic, it will no longer appear in the posting here on FS.com
Also: there is a size limit to the pictures that can be displayed here, I think it is 750 pixels in width, someone correct me if I am wrong. So you may need to resize (typically downsize) the pics so that they fit properly and all of the pic is displayed and not cropped. What I do is really simple: I email the original picture to myself within AOL. AOL will automatically prompt you to see if you want the picture "optimized". Say "yes" and send this new pic to yourself. I then save it with a "small" addendum to the picture name and put this optimized picture up on photobucket. It works every single time like a charm.
- Your car is a: 1976 spider
You beat me to it. You should see one on the drivers side too.
Trey
awesome! thanks for the help-that's one piece of relief!
