Oil pressure conclusion
Italchic
Post by Italchic »
Well after having connected a manual gauge to get an accurate reading which was normal, and after installing a new sending unit with which the gauge still reads to the low side, I can only conclude that the gauge is less than accurate, so I'll just try to not pay so much attention to it.
Re: Oil pressure conclusion
very common occurence on a Spider
Italchic
Post by Italchic »
So where are you in Southern Cal.? The reason I ask is that I just returned from San Diego and 5 days of Sun and 70 degreed temps. Perfect.
