how do u get that in, door rubber is thicker then the orginal, or it was just crimped in fter it was installed, anyways i spread my chrome peice a tad to get it in then i took a screw driver and hammer to crimp it back again, there has to be a better way
any one ever change theses.
top door rubber
top door rubber
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- manoa matt
Re: top door rubber
If your stretch the rubber window scraper it will thin out enough to slip into the stainless trim piece. I would not use a lubricant as the rubber will just slip out again.
Re: top door rubber
I got them in, I basically open up the ridge a tad and put it in, back on the car then took a flat screw driver and hit it with a hammer to put the crease tighter again, seems to workmanoa matt wrote:If your stretch the rubber window scraper it will thin out enough to slip into the stainless trim piece. I would not use a lubricant as the rubber will just slip out again.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- Your car is a: 1975 Spider
Re: top door rubber
also a touch of yellow weatherstrip adheasive in the bottom of the channel works well too, just not too much
son has 78 spider
son has 78 spider
Re: top door rubber
Ok thanksBEEK wrote:also a touch of yellow weatherstrip adheasive in the bottom of the channel works well too, just not too much
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
