Speedo hookup leaking
- JammerX19
How is this fixed? Is there a gasket? Mine is soaking wet.
Jody Farr
'74 124 Spider
'12 Fiat 500 Prima Edizione #13
'74 124 Spider
Re: Speedo hookup leaking
JammerX19, do you mean where the speedo cable hoks to the transmission. As far as I know that side of the speedo cable is a screq on and it is hard for big hand people to get up there. Two things. One, there is a little rubber gasket that goes over cable. Got one at Auto Ricambi. Two, use a set of extended long nose pliers of some other specialized thin wrench to carefully tighten the cable on the trans.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
