checking oil pressure
Italchic
Post by Italchic »
Decided to get a mech. oil press. gauge in order to get a more accurate reading (although today it was reading 40 at crusing speed). I'm just waiting for the metric adapter to arrive from Pep Boys. Will post results when I have them.
velozi
Re: checking oil pressure
Post by velozi »
I did the same thing and was able to finally have an accurate reading.
vandor
Post by vandor »
Having pressurized hot oil in the passenger compartment never seemed like a good idea to me.
A friend had his gauge spring a leak when he was driving his 'new' Spider from Arizona to Missouri. Not the type of repair you want to do on the side of the road!
TX82FIAT
Post by TX82FIAT »
Csaba, good point! I was considering this mod.... I think I can live with a little delay on the electric sensor more than oil all over the interior. In any event the oil pressure gauge is a piece of mind item in the event something does occur that may save your car someday.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
Italchic
Post by Italchic »
Well I did get the mech. gauge hooked up and the pressures were much better than the with the dash gauge: 40 at cold idle and up to 70 at 3000 rpm, obviously lower when it warmed and thinned. I was then thinking maybe I should just install the mech, gauge permanently but then the last two posts gave some some pause. If I did decide to do it how should the hose be routed and fed into the cabin?
velozi
Post by velozi »
I got some thin rubber hose from auto parts and passed the oil pressure hose inside. Tape the whole thing in electrical tape and got into the cabin the same way the electrical wires go in/out. There is space there for a new small hose.
TX82FIAT
Post by TX82FIAT »
Post some pics of the hook up and the line into the cabin. i'd like to see it as i am still curious. thanks, ray
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
