I am doing the timing belt and seals, and have gone through my manual and found the following, but am missing a couple of torque values not listed in the manual I have:
These I have:
Crankshaft Pulley Nut: 181 ft-lbs
Camshaft Pulley Bolts: 87 ft-lbs.
Tensioner Bearing Nut: 33 ft-lbs.
Do these jive with what you guys have in manuals/common knowledge etc?
What about torque values for these items:
Water Pump Pulley Bolts?
Aux Shaft Bolt?
Thanks. Pete.
Need some torque values
