Window Winding mechanism
georgeramos
Your car is a: 1971 124 Spider 1608
Post by georgeramos »
My passenger window mechanism quit today. i got the panel off and looked in there and nothing looks amiss. It seems the crank knob is "disengaged" from the mechanism itself as it just spins freely now. my question is: is the unit repairable or should i obtain a new one before pulling the glass etc out to remove the assembly?
Thanks all
George
narfire
Re: Window Winding mechanism
Post by narfire »
Is the crank knob plastic and the splines inside stripped?
georgeramos
no, the splined mechanism spins freely even with the handle removed.
George
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
The winding mechanism is cheap and not real hard to replace. I replaced the passenger side when I first bought the car. Take pictures , it will help with running the new cable. There are bolts coming up from the bottom of the door to give slack in the cable and to adjust tension.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
georgeramos
The Haynes manual says to remove the quarter glass and the window to change the mechanism. Is that what you did too Dennis?
Thanks for the reply.
George
dmwhiteoak
All I did was remove the door panel and worked from there. I saw no need to remove any glass. Once the old cable is removed the glass will slide up and down freely so prop it up with something as you route the cable. I accually have manuals
but never think to look at them before I start working on something. I don't understand why they would say to remove the quarter glass.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
georgeramos
Thats what i hoped you'd say! Thanks Dennis.
George
