Any difference between a blades and pigtail switch? I have both new ones for a 76 with a 78 radiator to replace this weekend.
If both do the same, any positives of using one over the other one except that small gain in space?
Rad Fan Switch Differences
- manoa matt
Re: Rad Fan Switch Differences
No differences except for the clearance, unless they are different temp ranges. The switches can be found in a range of temps.
