No fuel -> replaced fuel pump -> still no fuel
124Fan
Post by 124Fan »
The fuel pump on my '77 Spider is shot. While trying to start it, I noticed that the inline fuel filter remained completely dry.
I bought a new fuel pump, but it looks quite a bit different. The shape of the flipper arm is also different. I was skeptical, but they assured me that the pump works on a '77.
When installing it, I made sure that the it was leaned back to ensure that the flipper arm ended up on top of the aux shaft. No dice.
I've verified that the feed from the tank isn't blocked. Should this pump work? They told me it works with ALL 124 Spiders, but I'm starting to wonder if that's not the case.
Sonny
'74 124 Coupe (Gone), '72 124 Spider (Gone), '77 124 Spider (current project)
3rd generation Fiat grease monkey
124Fan
Re: No fuel -> replaced fuel pump -> still no fuel
Post by 124Fan »
Ok, checked international-auto.com and see that the fuel pump for the '72, '77, and the '79 all have different part numbers.
Sonny
tartan18
Your car is a: 1975 Fiat 124 Spider
Post by tartan18 »
124Fan wrote:The fuel pump on my '77 Spider is shot. While trying to start it, I noticed that the inline fuel filter remained completely dry.
Sonny
The lower mechanical pump in the photo is the one that works in my '75. The upper pump did not fit.
Jim MacKenzie
1975 Fiat Spider
