Rad fan
- courtenay
Re: Rad fan
Fan should turn in the direction that sucks air from the front to the back. That your temp gauge stays at 195 is a good thing.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Re: Rad fan
the fan should drop the temp about 10 degrees, then cycle off. If it stays at 195 and won't cool down you may have a plugged radiator
- bradartigue
Re: Rad fan
If it stays at 195 and the fan still cycles on and off then I'd question the gauge.So Cal Mark wrote:the fan should drop the temp about 10 degrees, then cycle off. If it stays at 195 and won't cool down you may have a plugged radiator
1970 124 Spider
http://www.artigue.com/fiat
