Hi guys,
I have been enjoying my 79 Spider this year though i recently started experiencing a problem when starting from a stop. As I let the clutch out the car starts shaking and it is difficult to get the car to move. if I am going down hill, it is easier. Changing gears from 1st -2nd, 2nd-3rd and so on are fine. It is just from a dead stop. I have to really gun it to get the car to move. Is it a slipping clutch? I have owned the car for 13 yrs and haven't had to do any transmission work. the transmission has always been strong. Let me know what you think.
Thanks.
Clutch slipping?
Clutch slipping?
SpyderJoe
79 Spider - 34 ADF w/ 1800 intake
Re: Clutch slipping?
Sure sounds like a worn or glazed clutch. How much free pedal travel do you have before before you feel resistance?
I haven't measured the free play in the clutch but there seems to be alot of play before there is any resistance. Is there a way to measure this along with a specification to compare the results against?
SpyderJoe
get rolling about 20mph and put it in 3rd gear and see how it accelerates. A slipping clutch will allow the engine to rev up under that load
- boogiedude
- Your car is a: 1978 spider 1800
Could be the input shaft bearing. Makes coming off the line very shakey when it goes bad.
Boogiedude, It shakes like a mutha' when I start to move. problem seems to be worse after it is driven and all warmed up.
I will try the 3rd gear take off to see how it performs.
SpyderJoe
You could crawl under the steering wheel with a ruler, but you should be able to estimate an inch or two with your foot pressing on the pedal. If the travel is more than halfway, as you've intimated, maybe a cable adjustment will keep you out of the shop for a little while. Loosen the lock nut jammed against the "acorn nut" at the transmission, and tighten clockwise a few turns at a time to get to the 2" zone.SpyderJoe wrote:I haven't measured the free play in the clutch but there seems to be alot of play before there is any resistance. Is there a way to measure this along with a specification to compare the results against?
thumping on take off is normally a sign of bad trans mount, broken flex joint or failed center support. Or if you're lucky, all 3 maladies at once
Thanks Mark. It is definitely clanking underneath but I thought it was my exhaust bouncing around because the car shakes so badly. It seems like the shaking is worse after driving for a while. Would this be a typical symptom of what you are suggesting? I will try and diagnose it this week/weekend and be back with my conclusions.
On a good note, I installed a new K&N filter setup and a sweet airhorn, (purchased at IAP), and it sounds nice. Now I just have to get it this issue fixed and I will be a happy camper.
SpyderJoe
Mark is speaking the truth. I recently had the front U-joint that had slipped off center in the yoke and it ended up breaking my flex joint and center bearing support bracket. It was hard to find the problem because I was checking for looseness in the U-joint and it was still solid. And it was causing clunking that sounded like exhaust banging on the body.
