Brakes
Observer
Your car is a: 81Spider Pininfarina
Brakes
Post by Observer »
very hard brake pedal.
Calipers are working
Flex lines good
Bleed the brakes
Vacume boost working
Can"t seem to find the problem
maytag
Re: Brakes
Post by maytag »
how do you know the vacuum boost is working?
Observer
Re: Brakes
Post by Observer »
maytag wrote:how do you know the vacuum boost is working?
Maybe I should of said "seems" to be working
With the engine off I pressed the pedal several times, held it down and started the engine. The pedal lowered slightly. I did this a couple of times and it responded the same.
baltobernie
Re: Brakes
Post by baltobernie »
With the engine running, when you press the brakes, do the RPMs change?
Observer
Re: Brakes
Post by Observer »
No change when engine is running.
