Temp Gauge
WarbirdAL
Your car is a: 2 1977 124 Spiders 1969 124 Coupe
Temp Gauge
Post by WarbirdAL »
temp gauge all the way to the right. Checked the wiring. When I disconnect the wiring from the sender on the head the gauge goes to the left. Engine is not overheating. Could it be the sender? Is there any trick to replacing it? Just unscrew it and screw the new one in? thanks!
WarbirdAL
Re: Temp Gauge
Post by WarbirdAL »
Sorry, I thought I had done a search for this issue before I typed it. Found my answer! Sometimes it is hard to resist the urge to ask in this forum with all the experts there before I search!
