Timing Question
- joelittel
Timing Question
Do you have to pull the fan out to check the timing on an '80 fuel injected model? I can't see my timing marks with the fan in place, is that right?
Re: Timing Question
It's real hard to see, but I can usually find a spot where I can sort of see them without removing anything.
- joelittel
Re: Timing Question
Real hard to see is an understatement. Is there a trick to it?
Re: Timing Question
I find the fan is not the issue but the thermostat is in the way a bit. Once I have the pointer and the crank mark painted (white), the timing light makes it easier to see.
- jfrawley
- Your car is a: 1982 Spider
Re: Timing Question
Not too technical but I use a small mirror that I slide behind the thermostat. It makes the timing marks real easy to see.
- 124JOE
Re: Timing Question
