Wire connector tool
redek
Wire connector tool
Post by redek »
Is there a tool for disconnecting the electrical connectors without damage? I started blasting and painting some parts, and would like to do the headlight buckets too.
Derek
Danq
Your car is a: 1981 2000 Spider
Re: Wire connector tool
Post by Danq »
Derek,
A small flat tip screw driver can be used to release the terminal in the headlight connector. there is a smaller slot opposite of the slot for the head light spade terminal. insert the screw driver into this slot and gently press on the tang of the contact.
For other types of connectors this tool is what you need.
http://www.tooltopia.com/lisle-56500.aspx
Dan
1981 spider 2000
