My Steering Box is Leaking from the Top???
donerehart
Your car is a: 1976 spider
Post by donerehart »
Team Fiat,
This is a new one for me and I need a little direction. My steering box started leaking from the top. :cry: I am pretty sure it is coming from the center adjustment screw and the nut on top. It is tight, but still leaking. What should I try to stop the leak, and what oil needs to go in there. I saw on one post that you should put some sort of "leak stop" in with the oil? What do you think about that?
Don
76 Spider
St. Louis, MO
