The other day I started a front end rebuild on my sons 78 1800 124 while it was on the rack I was looking under the block toward the flywheel and noticed the flywheel was exposed. I sthere suppose to be a cover over that fly wheel. When I replaced the clutch last winter I don't remember removing this bottom plate the top on was removed and replaced again. I think the PO may not have replaced the bottom cover. Because the car was on a rack this time I could get a good look at the flywheel from the front. I there is suppose to be a plate and vendors of the part would be helpful. I did not see at Vick's or IAP.
Ed Clark
404-234-7366
Is there a fly wheel cover I am missing.
- Your car is a: 1978 Fiat 124
Ed Clark
404-234-7366
Ed Clark
404-234-7366
Re: Is there a fly wheel cover I am missing.
there was a cover originally, mostly to keep small animals from crawling into the space
- Your car is a: 1982 Fiat 124 Spider
Mine was missing too but I got a "gently" used one from Bruce's Parts Bin.
Thanks Mark, Not sure if you are kidding. I though it might be to keep the small animals in that turn the drive shaft.
Thanks George, I will check with Bruce.
Ed Clark
404-234-7366
Ed Clark
404-234-7366
- 124JOE
its a flat cover you can trace it with cardboard and cut one from sheetsteel or AL
